Writing template files
Template files provide a framework-agnostic way to connect your code to Figma components. Instead of relying on framework-specific parsers, you write TypeScript files that explicitly define how your components should be displayed. This approach is simpler to maintain, more flexible, and more powerful than framework-specific APIs.
Template files give you full control over code generation, making them ideal when you need:
- Framework-agnostic connections: Connect any codebase, regardless of framework or language
- Precise code control: Generate exactly the code you want, without relying on parser APIs
We're actively investing in template files as the primary Code Connect format. If you're starting a new Code Connect integration or want to be involved in shaping its future, we encourage you to try it out and share feedback.
If you need to connect a large number of components that share the same code shape — such as an icon library — see Batch files for a more efficient approach that avoids creating one template file per component.
If you’re using an AI coding agent, the figma-code-connect skill helps you write Code Connect templates from a Figma component URL. For more about all the skills provided by Figma, see the Help Center.
Setup
- Make sure your
figma.config.jsonincludes.figma.ts(or.figma.js) files, and setlabelandlanguage(See Configuring your project):
"codeConnect": {
"include": ["**/*.figma.ts"],
"label": "React",
"language": "jsx"
- If using TypeScript, add the template type definitions to your
tsconfig.jsonso your editor can provide autocomplete and type checking in template files:
"compilerOptions": {
"types": ["@figma/code-connect/figma-types"]
Write your
.figma.tsfile (see Template file format) -
Publish your template files to Figma when ready:
npx figma connect publish
Template files connect your code to a component in Figma, and specify how instances of that component should appear in the code snippet. Here's an example file:
// url=https://www.figma.com/file/your-file-id/Component?node-id=123
import figma from 'figma'
const instance = figma.selectedInstance
const labelText = instance.getString('Label')
const iconInstance = instance.findInstance('Icon')
export default {
example: figma.code`
<MyComponent
label={${labelText}}
icon={${iconInstance.executeTemplate().example}}
imports: ['import MyComponent from "components/MyComponent"'],
metadata: {
nestable: true,
Metadata comments
Each template file must start with a block of special comments in the below format:
url- The Figma component your template is published to. In Figma, right-click on your component and select "Copy link to selection" or copy the URL from the browser.source(optional) - The filepath (or URL) of your code component. Is displayed in Figma.component(optional) - The name of your code component. Is displayed in Figma.
// source=src/components/MyButton.tsx
// component=MyButton
Building the snippet
The example snippet is the main part of the template file, describing how your code snippet should appear according to the Figma component instance.
Accessing instance properties
Use the methods on figma.selectedInstance to read properties from your Figma component:
// Get the value of the Figma instance "Label" string property
const label = instance.getString('Label')
// Get the value of the Figma instance "Disabled" boolean property
const disabled = instance.getBoolean('Disabled')
// Map the possible values of the "Size" enum property to code values
// (e.g. if the Figma "Size" property is "Small", map to 'sm' in code)
const size = instance.getEnum('Size', {
Small: 'sm',
Medium: 'md',
Large: 'lg',
Working with nested instances
To include nested component instances (like an icon inside a button), use findInstance() or getInstanceSwap() to locate the child, then call executeTemplate() to render it:
// Find a nested instance by layer name
// Get the snippet from the nested instance
const iconSnippet = iconInstance.executeTemplate().example
Important: While snippets are written in a string-like syntax, they use an array structure under the hood to ensure pills or errors can be rendered correctly.
It's important when you're building the snippet to not perform string operations (like concatenation) on them. Instead, wrap them in figma.code:
figma.code`<MyExample/>${showIcon ? iconSnippet : null}`
Working with slots
Slots are component properties that create flexible areas within a component, allowing freeform content editing. In code, slots typically correspond to children or content props, such as children in React, a content lambda in Jetpack Compose, or a @ViewBuilder parameter in SwiftUI.
When a Figma component has a slot property, use getSlot() to reference it in your template:
// Get the slot property named "Content"
const content = instance.getSlot('Content')
In Dev Mode, a slot renders as a clickable label with the slot property name. Clicking it selects the slot layer in the design. The remote Figma MCP server can also traverse into the slot to pull in layout details and any nested content.
To render the code for component instances placed directly in a slot, use its connectedInstances property. Each item is an InstanceHandle, so call executeTemplate() to include its connected example:
const slot = figma.selectedInstance.getSlot('Actions')
const actions = slot.connectedInstances.map((action) => action.executeTemplate().example)
const example = figma.code`<ActionBar>${actions.flat()}</ActionBar>`
Only instances with their own Code Connect definitions are included. The lookup is shallow: text, layers, unconnected instances, and instances nested inside another instance are omitted.
Choosing between slots and findConnectedInstances
Both approaches handle nested content, but the right choice depends on how predictable that content is.
Use getSlot() when the slot can hold freeform content: additional layout, mixed component types, or other frames whose structure varies. The slot renders as a clickable label in Dev Mode and lets the Figma MCP server traverse into it.
Use getSlot().connectedInstances when the slot contains code-connected components that can vary in type and order, and you want their code rendered inline. Unlike findConnectedInstances(), this keeps the lookup scoped to a specific slot property without requiring a selector.
Use findConnectedInstances() and render children inline when all children share the same component type and you want their full code expanded directly in the parent's snippet. For example, a select menu that only ever contains list items:
// List variant: all children are the same type, render them inline
const options = instance
.findConnectedInstances((node) => node.hasCodeConnect())
.map((child) => child.executeTemplate().example)
const example = figma.code`<Select>${options}</Select>`
findConnectedInstances takes two parameters:
selectorFn: (node: InstanceHandle) => boolean: filters which child instances to include. Thenodeargument exposes methods likehasCodeConnect(),codeConnectId(), andnameto help narrow down matches.opts(optional):traverseInstances: boolean— whentrue, searches recursively through nested instances, not just direct children. Defaults tofalse.path: string[]— restricts matches to instances at a specific position in the layer hierarchy, expressed as an ordered list of parent layer names.
// Custom variant: slot content is freeform, renders as a clickable label in the inspect panel
const example = figma.code`<Select>${content}</Select>`
Rendering your snippet
Finally, build your example by writing your code wrapped in figma.code:
const example = figma.code`Button(
variant = ButtonVariant.Primary
For the complete API including all available methods, helpers, and advanced features, see the Template API Reference.
Export format
Your template file should contain a default export in this format:
export default {
example: ResultSection[],
imports: string[]
metadata?: {
nestable?: boolean,
props?: Record<string, any>,
example- Your constructed snippet. Importantly, this should be wrapped infigma.code`<MyExample/>`imports- An array of strings that will be rendered at the top of your snippet. If the snippet is nested, the imports will be hoisted to the top and deduplicated.id- This identifies this Code Connect template, allowing other templates to reference itmetadatanestable(optional) - whether your snippet should be displayed inline if nested in a parent. Iffalse, displays as a clickable linkprops(optional) - makes data available to parent templates through executeTemplate().metadata.props
Migration script
If you have any feedback or issues with the script, please let us know by creating a GitHub issue.
The Code Connect command line tool offers a script to locally create template files from your existing Code Connect files. As this creates new files, we recommend committing any uncommitted changes in your codebase first. We also recommend using --outDir for testing for ease of publishing/unpublishing the new files.
By default, the migration script scans the current Code Connect project using your figma.config.json include/exclude settings. To migrate a folder or subtree, limit include/exclude in figma.config.json. Use --file to migrate one or more exact files from the selected project.
By default the migration script outputs .figma.ts files. If you need JavaScript output instead, pass the --javascript flag:
npx figma connect migrate [options]
Options:
--file <file...>— migrate one or more specific Code Connect files. If omitted, all files in project are migrated.--outDir <dir>— write template files to a specific directory instead of alongside the source files--javascript— output.figma.jsfiles instead of the default.figma.ts--delete— delete source Code Connect files after they are successfully migrated--batch <auto|all|none>— control batch migration. Defaults toauto, which attempts source files with 10 or more Code Connect connections. Useallto attempt every selected source file, ornoneto disable batch migration.--include-props— preserve__propsmetadata blocks in the migrated output. By default these are removed, since they are an implementation detail of parser-based files and are not needed in template files. Pass this flag if using the React.getProps()or.render()modifiers, or if you have other template files that readexecuteTemplate().metadata.__propsfrom the migrated components.
For the full command reference, see the CLI reference.
Migrated files
Treat the migration output as a starting point rather than production-ready Code Connect. The files will render correctly, but there are usually opportunities to simplify them — removing unnecessary helpers, cleaning up redundant props, and restructuring variant logic. See the sections below for the most common areas to review.
For most parser-based Code Connect files, the migration script writes one template file per connection. There are two exceptions:
- Files with variant restrictions are migrated into one template file with branching logic.
- Source files containing 10 or more Code Connect connections are automatically considered for batch file output. If the connections can share one safe template shape, the migration script writes one
.figma.batch.tsfile and one.figma.batch.jsonfile. If batching is not safe, the script shows a warning and falls back to regular one-template-per-connection output.
Passing --batch all attempts batch migration for every selected Code Connect source file, even if it contains fewer than 10 connections. This is useful for files you know should batch, and works well with --file:
npx figma connect migrate --file src/icons.figmadoc.tsx --batch all
Passing --batch none skips automatic batch attempts and always uses regular template output.
Migrated template files make use of figma.helpers to ensure correct rendering of code. If you know exactly how your code should appear, it may be simpler to remove some of these. For example, if you're rendering a required prop in React that is always of a known type, then this code:
figma.code`<Counter${figma.helpers.react.renderProp('count', count)} />`
Can be simplified to:
figma.code`<Counter count={${count}} />`
Batch migration review
Automatic batch migration is intentionally conservative. It only creates a batch when every connection in a source file can reduce to one compatible template shape using readable figma.batch.* parameters. For example, it can usually handle icon-style files where the component name, id, import member, or simple named values like name="..." or size={...} vary between connections. It avoids parameterizing arbitrary text, complex expressions, aliases, or unrelated template shapes.
When batching succeeds, review both generated files:
- The
.figma.batch.tsfile should be easy to read and should contain only fields that are common to every connection. - The
.figma.batch.jsonfile should contain the Figmaurlfor each connection and any values that vary per connection.
When batching fails, the migrated regular template files are still valid. If you want to manually convert them into batch files, you can use this prompt with your coding agent:
I migrated parser-based Code Connect to template files. Some of these generated files are related and similar enough to be replaced with a single batch JSON file and template.
Start by reading the docs to understand the exact format: https://developers.figma.com/docs/code-connect/batch-files/
Find template files that are good candidates to be converted into batch files, then migrate them. Be meticulous and skip any that can't be cleanly migrated.
Prefer high-volume groups such as icon sets. Skip small groups unless the win is very obvious.
When testing in a repo without a local figma CLI binary, use:
npx --yes --package @figma/code-connect figma connect parse --file {path}
If adding any JSON files, make sure the figma.config.json includes them, e.g. `**/*.figma.batch.json`.
It is expected to delete the individual template files only after the batch file parses and preserves the same Code Connect docs.
Test the before/after using `npx figma connect parse --file {pathToTemplateFileOrBatchJson}`
Variant restrictions
Components that used variant restrictions (multiple figma.connect calls pointing to the same Figma URL with different variant objects) are migrated into a single file with an if/else-if/else branching structure. For example:
// Migration output
let template
if (figma.selectedInstance.getPropertyValue('Has Label') === 'true') {
template = {
example: figma.code`<InputField label={${label}} />`,
imports: ['import { InputField } from "./InputField"'],
} else {
template = {
example: figma.code`<Input />`,
imports: ['import { Input } from "./Input"'],
export default template
This structure works but is verbose and requires more manual review than other migration output. In most cases it can be simplified using getBoolean(), getEnum(), or standard conditional logic:
// Cleaned up
const hasLabel = figma.selectedInstance.getBoolean('Has Label')
export default {
example: hasLabel
? figma.code`<InputField label={${label}} />`
imports: hasLabel
? ['import { InputField } from "./InputField"']
When reviewing migrated variant files, pay particular attention to:
- Conditions using
getPropertyValue(): these are a direct translation of the original variant restrictions and can usually be replaced with typed methods likegetBoolean()orgetEnum(). - One Figma component mapping to multiple code components: when different property values should render entirely different components (as in the example above), the cleaned-up version often uses a ternary or early return rather than a full if/else block.
- Multiple variant properties AND'd together: the migration generates
getPropertyValue('A') === 'x' && getPropertyValue('B') === 'y'conditions. These can often be simplified or collapsed usinggetEnum()with a mapping object.
Testing in Figma
For testing out these changes in Figma, you will need to set up your figma.config.json. We recommend setting label to a temporary value so you can easily publish / unpublish without affecting your existing Code Connect, and limiting include to only publish the new files. See Setup for more details on these values.
"label": "TEST",
"language": "jsx"
You can then publish under your temporary label to test these out in Figma :
npx figma connect publish --config <your figma.config.json path>
When you're done, you can remove these from Figma with unpublish:
npx figma connect unpublish --config <your figma.config.json path>
