Endpoints
See information about your folders, subfolders, and files within a folder.
info
Limited Access
The endpoints that require the folders:read scope cannot be used with public OAuth apps. GET folder metadata, which requires folder_metadata:read, is available to all OAuth apps.
info
API versions apply per endpoint. The /v2 folder endpoints replace deprecated project endpoints; the /v1 endpoints are separate operations.
GET folder metadata​
Returns basic metadata about a folder — its name, thumbnail, file count, and timestamps — without enumerating its files. Use this when you need a lightweight folder preview, such as for link unfurling or search results. This is the v2 replacement for the project metadata endpoint. thumbnail_url may be null if the folder has no files.
info
This is a Tier 3 endpoint and requires the folder_metadata:read scope.
HTTP Endpoint​
GET /v2/folders/:folder_id/meta
Return value
"id": String,
"name": String,
"thumbnail_url": String,
"file_count": Number,
"updated_at": String,
"created_at": String
Path parametersDescription
folder_id
String
ID of the folder to get metadata for
Error codesDescription
403The developer / OAuth token is invalid or expired, or does not have access to the folder
404The specified folder was not found
429The request was rate-limited
GET team folders​
Get a list of the top-level folders within the specified team. It returns only folders visible to the authenticated user or owner of the token, accounting for direct roles, inherited access, sharing audience controls, and user groups. Each returned folder has a null parent_folder_id. Use GET folder subfolders to traverse into subfolders.
It is not possible to programmatically obtain team IDs. To obtain a team ID, navigate to the team page in the Figma file browser. The team ID is present in the URL after the word team. For example, in https://www.figma.com/files/181033233908053158/team/1535685101263221741, the team ID is 1535685101263221741.
info
This is a Tier 2 endpoint and requires the folders:read scope.
HTTP Endpoint​
GET /v2/teams/:team_id/folders
team_id
String
ID of the team to list folders from
400Error with the request. The "message" param on the response will describe the error.
403The developer / OAuth token is invalid or expired, or does not have access to the team
404The specified team was not found
GET folder subfolders​
List the direct subfolders within a given folder (folders whose parent_folder_id equals the requested folder's ID). It returns only folders visible to the authenticated user or owner of the token.
info
HTTP Endpoint​
GET /v2/folders/:folder_id/folders
folder_id
String
ID of the parent folder to list subfolders from
GET folder files​
List the files directly within a given folder. It returns only files visible to the authenticated user or owner of the token.
info
HTTP Endpoint​
GET /v2/folders/:folder_id/files
folder_id
String
ID of the folder to list files from
Query parametersDescription
branch_data
Booleandefault: false
Returns branch metadata in the response for each main file with a branch inside the folder.
400Error with the request. The message param on the response will describe the error.
POST team folder​
Creates a top-level folder in a team. The team must belong to the Enterprise plan associated with the private OAuth app, and the authenticated user must be allowed to create a folder in the team.
info
This is a Tier 2 endpoint, requires the folders:write scope, and is available only to private OAuth apps associated with an Enterprise plan.
HTTP Endpoint​
POST /v1/teams/:team_id/folders
team_id
String
The ID of the team in which to create the folder.
Body parametersDescription
name
String
The name of the folder.
sharing_audience_control
String
The audience that can access the folder: plan_view, plan_edit, invite_only, workspace_view, or workspace_edit. Workspace audiences require the specified team to belong to a workspace.
Return value
Returns the created Folder, including sharing_audience_control and created_at.
400The request parameters are invalid.
401The access token is missing or incorrect.
403The caller does not have permission to create the folder.
404The requested resource was not found.
429The request was rate-limited.
500An internal server error occurred.
