Node types
Node type indicates what kind of node you are working with: for example, a FRAME node versus a RECTANGLE node. A node can have additional properties associated with it depending on its node type. The following is a catalog of properties that can be applied to a node, grouped by node type.
Node typeProperties
DOCUMENT
childrenNode[]
An array of canvases attached to the document.
CANVAS
childrenNode[]
An array of top level layers on the canvas.
backgroundColorColor
Background color of the canvas.
prototypeStartNodeIDStringdeprecated
Node ID that corresponds to the start frame for prototypes. This is deprecated with the introduction of multiple flows. Please use the flowStartingPoints field.
flowStartingPointsFlowStartingPoint[]default: []
A array of flow starting points sorted by its position in the prototype settings panel.
prototypeDevicePrototypeDevice
The device used to view a prototype.
exportSettingsExportSettingsdefault: []
Export settings for the canvas.
measurementsMeasurement[]default: []
An array of measurements displaying pinned distances between nodes on the canvas in Dev Mode.
FRAME
childrenNode[]
An array of nodes that are direct children of this node.
lockedBooleandefault: false
If true, layer is locked and cannot be edited.
backgroundPaint[]deprecated
Background of the node. This is deprecated, as backgrounds for frames are now in the fills field.
backgroundColorColordeprecated
Background color of the node. This is deprecated, as frames now support more than a solid color as a background. Please use the fills field instead.
fillsPaint[]default: []
An array of fill paints applied to the node.
strokesPaint[]default: []
An array of stroke paints applied to the node.
complexStrokePropertiesComplexStrokePropertiesdefault: {}
cspdesc
variableWidthPointsVariableWidthPoint[]default: []
A list of points describing the width profile of variable width strokes.
strokeWeightNumber
The weight of strokes on the node.
strokeAlignString
Position of stroke relative to vector outline, as a string enum.
  • INSIDE: stroke drawn inside the shape boundary
  • OUTSIDE: stroke drawn outside the shape boundary
  • CENTER: stroke drawn centered along the shape boundary
strokeDashesNumber[]default: []
An array of floating point numbers describing the pattern of dash length and gap lengths that the vector path follows. For example a value of [1, 2] indicates that the path has a dash of length 1 followed by a gap of length 2, repeated.
cornerRadiusNumber
Radius of each corner of the frame if a single radius is set for all corners.
rectangleCornerRadiiNumber[]default: same as cornerRadius
Array of length 4 of the radius of each corner of the rectangle, starting in the top left and proceeding clockwise.
cornerSmoothingNumberdefault: 0
A value that lets you control how "smooth" the corners are. Ranges from 0 to 1. 0 means that the corner is perfectly circular. A value of 0.6 means the corner matches the iOS 7 "squircle" icon shape. Other values produce various other curves. See this post for the gory details!
exportSettingsExportSettings[]default: []
An array of export settings representing images to export from the node.
blendModeBlendMode
How this node blends with nodes behind it in the scene (see blend mode section for more details).
preserveRatioBooleandeprecateddefault: false
Keep height and width constrained to same ratio. Deprecated in favor of targetAspectRatio.
targetAspectRatio0
If set, keeps height and width constrained to the target aspect ratio. Unlike preserveRatio, also works outside of properties panel resizing actions.
constraintsLayoutConstraint
Horizontal and vertical layout constraints for the node.
layoutAlignString
Determines if the layer should stretch along the parent's counter axis. This property is only provided for direct children of auto-layout frames.
  • INHERIT
  • STRETCH
In previous versions of auto layout, determined how the layer is aligned inside an auto-layout frame. This property is only provided for direct children of auto-layout frames.
  • MIN
  • CENTER
  • MAX
  • STRETCH
In horizontal auto-layout frames, MIN and MAX correspond to TOP and BOTTOM. In vertical auto-layout frames, MIN and MAX correspond to LEFT and RIGHT.
interactionsInteraction[]
List of prototype interactions on this node, which includes both the method of interaction with this node in a prototype, and the behavior of that interaction.
transitionNodeIDStringdefault: null
Node ID of node to transition to in prototyping.
transitionDurationNumberdefault: null
The duration of the prototyping transition on this node (in milliseconds).
transitionEasingEasingTypedefault: null
The easing curve used in the prototyping transition on this node.
opacityNumberdefault: 1
Overall opacity of paint (colors within the paint can also have opacity values which would blend with this).
absoluteBoundingBoxRectangle
Bounding box of the node in absolute space coordinates.
absoluteRenderBounds0
The actual bounds of a node accounting for drop shadows, thick strokes, and anything else that may fall outside the node's regular bounding box defined in x, y, width, and height. The x and y inside this property represent the absolute position of the node on the page. This value will be null if the node is invisible.
sizeVector
Width and height of element. This is different from the width and height of the bounding box in that the absolute bounding box represents the element after scaling and rotation. Only present if geometry=paths is passed.
minWidthNumber | nulldefault: null
The minWidth of the frame, or null if not set.
maxWidthNumber | nulldefault: null
The maxWidth of the frame, or null if not set.
minHeightNumber | nulldefault: null
The minHeight of the frame, or null if not set.
maxHeightNumber | nulldefault: null
The maxHeight of the frame, or null if not set.
relativeTransformTransform
The top two rows of a matrix that represents the 2D transform of this node relative to its parent. The bottom row of the matrix is implicitly always (0, 0, 1). Use to transform coordinates in geometry. Only present if geometry=paths is passed.
clipsContentBoolean
Whether or not this node clips content outside of its bounds.
layoutModeStringdefault: NONE
Whether this layer uses auto-layout to position its children.
  • NONE
  • HORIZONTAL
  • VERTICAL
  • GRID
layoutSizingHorizontalString
The horizontal sizing setting on this auto-layout frame or frame child.
  • FIXED
  • HUG
  • FILL
HUG is only valid on auto-layout frames and text nodes. FILL is only valid on auto-layout frame children.
layoutSizingVerticalString
The vertical sizing setting on this auto-layout frame or frame child.
  • FIXED
  • HUG
  • FILL
layoutWrapString
Whether this auto-layout frame has wrapping enabled.
  • NO_WRAP
  • WRAP
primaryAxisSizingModeStringdefault: AUTO
Whether the primary axis has a fixed length (determined by the user) or an automatic length (determined by the layout engine). This property is only applicable for auto-layout frames.
  • FIXED
  • AUTO
counterAxisSizingModeStringdefault: AUTO
Whether the counter axis has a fixed length (determined by the user) or an automatic length (determined by the layout engine). This property is only applicable for auto-layout frames.
  • FIXED
  • AUTO
primaryAxisAlignItemsStringdefault: MIN
Determines how the auto-layout frame’s children should be aligned in the primary axis direction. This property is only applicable for auto-layout frames.
  • MIN
  • CENTER
  • MAX
  • SPACE_BETWEEN
counterAxisAlignItemsStringdefault: MIN
Determines how the auto-layout frame’s children should be aligned in the counter axis direction. This property is only applicable for auto-layout frames.
  • MIN
  • CENTER
  • MAX
  • BASELINE
counterAxisAlignContentStringdefault: AUTO
Determines how the auto-layout frame’s wrapped tracks should be aligned in the counter axis direction. This property is only applicable for auto-layout frames with layoutWrap: "WRAP".
  • AUTO
  • SPACE_BETWEEN
gridRowCountNumber
The number of rows in the grid layout. This property is only applicable for auto-layout frames with layoutMode: "GRID".
gridColumnCountNumber
The number of columns in the grid layout. This property is only applicable for auto-layout frames with layoutMode: "GRID".
gridRowGapNumberdefault: 0
The distance between rows in the grid layout. This property is only applicable for auto-layout frames with layoutMode: "GRID".
gridColumnGapNumberdefault: 0
The distance between columns in the grid layout. This property is only applicable for auto-layout frames with layoutMode: "GRID".
gridColumnsSizingString
The string for the CSS grid-template-columns property. This property is only applicable for auto-layout frames with layoutMode: "GRID".
gridRowsSizingString
The string for the CSS grid-template-rows property. This property is only applicable for auto-layout frames with layoutMode: "GRID".
gridAutoTracksStringdefault: NONE
Controls how frames with layoutMode: "GRID" handle automatic row creation.
  • NONE: the row count is controlled by the user-set value of gridRowCount, but will never be below the number of necessary rows to hold all items within the grid.
  • ROWS: new rows are added automatically as children are appended, and removed if a row becomes empty.
gridItemsPositioningStringdefault: MANUAL
Controls how children are positioned within the grid. This property is only applicable for auto-layout frames with layoutMode: "GRID".
  • MANUAL: children are placed in explicitly assigned grid cells.
  • ROW_AUTO_FLOW: children automatically flow into the next available cell in row-major order.
gridChildHorizontalAlignStringdefault: AUTO
Determines how a GRID frame's child should be aligned in the horizontal direction within its grid area. This property is only applicable for direct children of frames with layoutMode: "GRID".
  • AUTO
  • MIN
  • CENTER
  • MAX
gridChildVerticalAlignStringdefault: AUTO
Determines how a GRID frame's child should be aligned in the vertical direction within its grid area. This property is only applicable for direct children of frames with layoutMode: "GRID".
  • AUTO
  • MIN
  • CENTER
  • MAX
gridRowSpanNumberdefault: 1
The number of rows that a GRID frame's child should span. This property is only applicable for direct children of frames with layoutMode: "GRID".
gridColumnSpanNumberdefault: 1
The number of columns that a GRID frame's child should span. This property is only applicable for direct children of frames with layoutMode: "GRID".
gridColumnAnchorIndexNumberdefault: 0
The index of the column that a GRID frame's child should be anchored to. This property is only applicable for direct children of frames with layoutMode: "GRID".
gridRowAnchorIndexNumberdefault: 0
The index of the row that a GRID frame's child should be anchored to. This property is only applicable for direct children of frames with layoutMode: "GRID".
paddingLeftNumberdefault: 0
The padding between the left border of the frame and its children. This property is only applicable for auto-layout frames.
paddingRightNumberdefault: 0
The padding between the right border of the frame and its children. This property is only applicable for auto-layout frames.
paddingTopNumberdefault: 0
The padding between the top border of the frame and its children. This property is only applicable for auto-layout frames.
paddingBottomNumberdefault: 0
The padding between the bottom border of the frame and its children. This property is only applicable for auto-layout frames.
horizontalPaddingNumberdeprecateddefault: 0
The horizontal padding between the borders of the frame and its children. This property is only applicable for auto-layout frames. Deprecated in favor of setting individual paddings.
verticalPaddingNumberdeprecateddefault: 0
The vertical padding between the borders of the frame and its children. This property is only applicable for auto-layout frames. Deprecated in favor of setting individual paddings.
itemSpacingNumberdefault: 0
The distance between children of the frame. Can be negative. This property is only applicable for auto-layout frames.
counterAxisSpacingNumberdefault: 0
The distance between wrapped tracks of an auto-layout frame. This property is only applicable for auto-layout frames with layoutWrap: "WRAP".
layoutPositioningStringdefault: AUTO
Determines whether a layer's size and position should be determined by auto-layout settings or manually adjustable.
  • ABSOLUTE
  • AUTO
itemReverseZIndexBooleandefault: false
Determines the canvas stacking order of layers in this frame. When true, the first layer will be draw on top. This property is only applicable for auto-layout frames.
strokesIncludedInLayoutBooleandefault: false
Determines whether strokes are included in layout calculations. When true, auto-layout frames behave like css box-sizing: border-box. This property is only applicable for auto-layout frames.
layoutGridsLayoutGrid[]default: []
An array of layout grids attached to this node (see layout grids section for more details). GROUP nodes do not have this attribute.
overflowDirectionStringdefault: NONE
Defines the scrolling behavior of the frame, if there exist contents outside of the frame boundaries. The frame can either scroll vertically, horizontally, or in both directions to the extents of the content contained within it. This behavior can be observed in a prototype.
  • HORIZONTAL_SCROLLING
  • VERTICAL_SCROLLING
  • HORIZONTAL_AND_VERTICAL_SCROLLING
  • NONE
effectsEffect[]default: []
An array of effects attached to this node (see effects section for more details).
isMaskBooleandefault: false
Does this node mask sibling nodes in front of it?
isMaskOutlineBooleandeprecateddefault: false
Whether the mask ignores fill style (e.g. gradients) and effects. This property is deprecated; please use the maskType field instead (isMaskOutline=true corresponds to maskType="VECTOR").
maskTypeString
If this layer is a mask, this property describes the operation used to mask the layer's siblings. The value may be one of the following:
  • ALPHA: the mask node's alpha channel will be used to determine the opacity of each pixel in the masked result.
  • VECTOR: if the mask node has visible fill paints, every pixel inside the node's fill regions will be fully visible in the masked result. If the mask has visible stroke paints, every pixel inside the node's stroke regions will be fully visible in the masked result.
  • LUMINANCE: the luminance value of each pixel of the mask node will be used to determine the opacity of that pixel in the masked result.
stylesMap<String, String>
A mapping of a style_type to style ID (see Style for more details) of styles present on this node. The style ID can be used to look up more information about the style in the top-level styles field.
devStatus0default: null
Whether the node is marked Ready for dev or Completed. If the node does not have a status, the property is null.
annotationsAnnotation[]default: []
An array of annotations displaying notes and pinned properties of nodes. Currently a maximum of 1 annotation is supported.
GROUP
See properties for FRAME.
TRANSFORM_GROUP
[Available in beta, API is subject to change] A group that represents a node transform.
Transform groups have all of the properties of a FRAME, plus:
transformModifiersTransformModifier[]default: []
SECTION
sectionContentsHiddenBooleandefault: false
Whether the contents of the section are visible.
Whether the section is marked Ready for dev or Completed. If the section does not have a status, the property is null.
complexStrokePropertiesComplexStrokePropertiesdefault: {"type": "BASIC"}
cspdesc
strokeWeightNumber
strokeAlignString
childrenNode[]
An array of nodes that are contained in the section.
VECTOR
exportSettingsExportSetting[]default: []
blendModeBlendMode
preserveRatioBooleandefault: false
layoutAlignString
Determines if the layer should stretch along the parent’s counter axis. This property is only provided for direct children of auto-layout frames.
  • INHERIT
  • STRETCH
  • MIN
  • CENTER
  • MAX
  • STRETCH
layoutGrowNumberdefault: 0
This property is applicable only for direct children of auto-layout frames, ignored otherwise. Determines whether a layer should stretch along the parent's primary axis. A 0 corresponds to a fixed size and 1 corresponds to stretch.
Horizontal and vertical layout constraints for node.
transitionNodeIDString | nulldefault: null
transitionDurationNumber | nulldefault: null
Opacity of the node.
sizeVector
fillGeometryPath[]default: []
An array of paths representing the object fill. Only present if parameter geometry=paths is used.
fillOverrideTableMap<Number, PaintOverride>
Map from ID to PaintOverride for looking up fill overrides. To see which regions are overriden, you must use the geometry=paths option. Each path returned may have an overrideId which maps to this table.
cspdesc
strokeWeightNumber
individualStrokeWeightsStrokeWeights
An object including the top, bottom, left, and right stroke weights. Only returned if individual stroke weights are used.
strokeCapString
A string enum with values describing the end caps of vector paths.
  • NONE
  • ROUND
  • SQUARE
  • LINE_ARROW
  • TRIANGLE_ARROW
  • DIAMOND_FILLED
  • CIRCLE_FILLED
  • TRIANGLE_FILLED
  • WASHI_TAPE_1
  • WASHI_TAPE_2
  • WASHI_TAPE_3
  • WASHI_TAPE_4
  • WASHI_TAPE_5
  • WASHI_TAPE_6
strokeJoinString
How corners in vector paths are rendered, as a string enum.
  • MITER
  • BEVEL
  • ROUND
An array of floating point numbers describing the pattern of dash length and gap lengths that the vector stroke will use when drawn. For example a value of [1, 2] indicates that the stroke will be drawn with a dash of length 1 followed by a gap of length 2, repeated.
strokeMiterAngleNumberdefault: 28.96
Only valid if strokeJoin is MITER. The corner angle, in degrees, below which strokeJoin will be set to BEVEL to avoid super sharp corners. By default this is 28.96 degrees.
strokeGeometryPath[]
Only specified if parameter geometry=paths is used. An array of paths representing the object stroke.
strokeAlignString
BOOLEAN_OPERATION
Has all the properties of VECTOR except annotations, plus:
childrenNode[]
An array of nodes that are being boolean operated on.
booleanOperationString
The type of boolean operation applied, as a string enum.
  • UNION
  • INTERSECT
  • SUBTRACT
  • EXCLUDE
STAR
See properties for VECTOR.
LINE
ELLIPSE
Has all the properties of VECTOR, plus:
arcDataArcData
Start and end angles of the ellipse measured clockwise from the x axis, plus the inner radius for donuts.
REGULAR_POLYGON
RECTANGLE
cornerRadiusNumber
Radius of each corner of the rectangle if a single radius is set for all corners.
A value that lets you control how "smooth" the corners are. Ranges from 0 to 1. 0 is the default and means that the corner is perfectly circular. A value of 0.6 means the corner matches the iOS 7 "squircle" icon shape. Other values produce various other curves. See this post for the gory details!
TABLE
FigJam table node.
blendModeBlendMode
childrenNode[]
An array of table cell nodes within the table. The table cells are sorted by row, then column.
sizeVector
cspdesc
strokeAlignString
strokeWeightNumber
TABLE_CELL
FigJam table cell node.
charactersString
Text contained within a text box.
sizeVector
TEXT
Has all the properties of VECTOR except fillOverrideTable, plus:
charactersString
styleTypeStyle
Style of text including font family and weight (see type style section for more information).
characterStyleOverridesNumber[]
The array corresponds to characters in the text box, where each element references the styleOverrideTable to apply specific styles to each character. The array's length can be less than or equal to the number of characters due to the removal of trailing zeros. Elements with a value of 0 indicate characters that use the default type style. If the array is shorter than the total number of characters, the characters beyond the array's length also use the default style.
styleOverrideTableMap<Number, TypeStyle>
Map from ID to TypeStyle for looking up style overrides.
lineTypesLineType[]
An array with the same number of elements as lines in the text node, where lines are delimited by newline or paragraph separator characters. Each element in the array corresponds to the list type of a specific line. List types are represented as string enums with one of these possible values:
  • ORDERED: Text is an ordered list (numbered).
  • UNORDERED: Text is an unordered list (bulleted).
  • NONE: Text is plain text and not part of any list.
lineIndentationsNumber[]
An array with the same number of elements as lines in the text node, where lines are delimited by newline or paragraph separator characters. Each element in the array corresponds to the indentation level of a specific line.
TEXT_PATH
[Available in beta, API is subject to change] Has all the properties of VECTOR except fillOverrideTable, plus:
charactersString
Text contained within the text path.
styleTextPathTypeStyle
Style of text including font family and weight (see TextPathTypeStyle section for more information).
The array corresponds to characters in the text path, where each element references the styleOverrideTable to apply specific styles to each character. The array's length can be less than or equal to the number of characters due to the removal of trailing zeros. Elements with a value of 0 indicate characters that use the default type style. If the array is shorter than the total number of characters, the characters beyond the array's length also use the default style.
styleOverrideTableMap<Number, TextPathTypeStyle>
Map from ID to TextPathTypeStyle for looking up style overrides.
textPathStartDataTextPathStartData
Data describing the starting position of the text on the path.
SLICE
sizeVector
COMPONENT
Has all the properties of FRAME, plus:
componentPropertyDefinitionsMap<String, ComponentPropertyDefinition>default: {}
A mapping of name to ComponentPropertyDefinition for every component property on this component. Each property has a type, defaultValue, and other optional values (see property types section below)
COMPONENT_SET
A mapping of name to ComponentPropertyDefinition for every component property on this component set. Each property has a type, defaultValue, and other optional values (see property types section below)
INSTANCE
componentIdString
ID of component that this instance came from, refers to components table (see endpoints section below).
isExposedInstanceBooleandefault: false
If true, this node has been marked as exposed to its containing component or component set.
exposedInstancesString[]default: []
IDs of instances that have been exposed to this node's level.
componentPropertiesMap<String, ComponentProperty>default: {}
A mapping of name to ComponentProperty for all component properties on this instance. Each property has a type, value, and other optional values (see property types section below)
overridesOverrides[]default: []
An array of all of the fields directly overridden on this instance. Inherited overrides are not included.
STICKY
FigJam sticky node.
authorVisibleBooleandefault: false
If true, author name is visible.
Background color of the node. This is deprecated, please use the fills field instead.
blendModeBlendMode
charactersString
If true, sticky is locked and cannot be edited.
opacityNumber
SHAPE_WITH_TEXT
FigJam Shape-with-text node.
blendModeBlendMode
charactersString
cornerRadiusNumber
If true, shape-with-text is locked and cannot be edited.
opacityNumber
shapeTypeShapeType
Shape-with-text geometric shape type.
cspdesc
strokeWeightNumber
strokeCapString
The end cap of vector paths, as a string enum.
  • NONE
  • ROUND
  • SQUARE
  • LINE_ARROW
  • TRIANGLE_ARROW
  • DIAMOND_FILLED
  • CIRCLE_FILLED
  • TRIANGLE_FILLED
  • WASHI_TAPE_1
  • WASHI_TAPE_2
  • WASHI_TAPE_3
  • WASHI_TAPE_4
  • WASHI_TAPE_5
  • WASHI_TAPE_6
strokeJoinStringdefault: MITER
  • MITER
  • BEVEL
  • ROUND
strokeAlignString
stylesMap<StyleType, String>
A mapping of a StyleType to style ID (see Style of styles present on this node. The style ID can be used to look up more information about the style in the top-level styles field.
CONNECTOR
FigJam connector node.
blendModeBlendMode
charactersString
connectorStartConnectorEndpoint
Connector starting endpoint.
connectorEndConnectorEndpoint
Connector ending endpoint.
connectorStartStrokeCapStringdefault: NONE
The end cap of the start of the connector, as a string enum.
  • NONE
  • LINE_ARROW
  • TRIANGLE_ARROW
  • DIAMOND_FILLED
  • CIRCLE_FILLED
  • TRIANGLE_FILLED
connectorEndStrokeCapStringdefault: NONE
The end cap of the end of the connector, as a string enum.
  • NONE
  • LINE_ARROW
  • TRIANGLE_ARROW
  • DIAMOND_FILLED
  • CIRCLE_FILLED
  • TRIANGLE_FILLED
connectorLineTypeConnectorLineType
Connector line type.
cornerRadiusNumber
If true, connector is locked and cannot be edited.
opacityNumber
cspdesc
strokeWeightNumber
strokeCapStringdefault: NONE
  • NONE
  • ROUND
  • SQUARE
  • LINE_ARROW
  • TRIANGLE_ARROW
  • DIAMOND_FILLED
  • CIRCLE_FILLED
  • TRIANGLE_FILLED
  • WASHI_TAPE_1
  • WASHI_TAPE_2
  • WASHI_TAPE_3
  • WASHI_TAPE_4
  • WASHI_TAPE_5
  • WASHI_TAPE_6
  • MITER
  • BEVEL
  • ROUND
strokeAlignString
textBackgroundConnectorTextBackground
Connector text background.
WASHI_TAPE
