What does the MCP server do, and what does my agent do?
The MCP server isn't a one-click way to turn designs into finished code. It connects Figma to your MCP client and gives your agent structured design information to work from.
The MCP server:
  • Gets structured design context from the Figma layers you choose, including frames, components, layout, and variables
  • Passes that context to your agent, such as Claude Code, Cursor, or GitHub Copilot
  • Helps your agent reuse your real components and variables when you use features like Code Connect and variable code syntax
Your agent:
  • Writes the final code, adapting the layout, reusing components, and following your prompts and codebase
  • Only knows your design system conventions if you share them through Code Connect, variables, rules, or your prompts
  • Produces results that depend on the quality of the context, the model, and how clear your prompt is
