Endpoints
The following sections list the endpoints that are available for the SCIM API. All of the endpoints use the same base URL.
Configuration endpoints
GET Service Provider Config
Get Figma's configuration details for the SCIM API, including which operations are supported.
HTTP endpoint
GET :baseURL/ServiceProviderConfig
Response
"schemas": ["urn:ietf:params:scim:schemas:core:2.0:ServiceProviderConfig"],
"documentationUri": "https://help.figma.com/hc/en-us/articles/360048514653-Set-up-automatic-provisioning-via-SCIM",
"patch": {
"supported": true
"bulk": {
"supported": false,
"maxOperations": 0,
"maxPayloadSize": 0
"filter": {
"supported": true,
"maxResults": 200
"changePassword": {
"supported": false
"sort": {
"supported": false
"etag": {
"supported": false
"authenticationSchemes": [
"name": "OAuth Bearer Token",
"description": "Authentication scheme using the OAuth Bearer Token Standard",
"specUri": "http://www.rfc-editor.org/info/rfc6750",
"type": "oauthbearertoken",
"primary": true
"meta": {
"location": "https://www.figma.com/v2/ServiceProviderConfig",
"resourceType": "ServiceProviderConfig",
"created": "2020-09-01T04:56:22Z",
"lastModified": "2020-09-01T04:56:22Z",
"version": "1"
GET Tenant ID
Used to check if a tenant ID is valid. Returns 200 if the tenant ID is valid, returns 400 if the tenant ID is not valid.
HTTP endpoint
GET :baseURL
Response
200
Users endpoints
The following endpoints are used to work with SCIM managed users.
GET Users
Returns a list of currently SCIM provisioned users in the organization. This will 'bind' the user accounts to the SCIM table.
HTTP endpoint
GET :baseURL/Users
Example paths
GET :baseURL/Users?filter&count&startIndex
GET :baseURL/Users?filter=userName eq "email@domain.com"
GET :baseURL/Users?filter=externalId eq "external-id-value"
Headers
Authorization: Bearer [FIGMA API TOKEN]
Parameters
| Path parameter | Description |
| filter |
| count |
| startIndex |
Example response
"schemas": ["urn:ietf:params:scim:api:messages:2.0:ListResponse"],
"totalResults": 1,
"Resources": [
"name": {
"givenName": "Scim",
"familyName": "User"
"roles": [
"type": "seatType",
"value": "Dev"
"title": "Developer",
"emails": {
"type": "work",
"value": "scimuser@example.com",
"primary": "true"
"schemas": [
"urn:ietf:params:scim:schemas:core:2.0:User",
"urn:ietf:params:scim:schemas:extension:enterprise:2.0:User",
"urn:ietf:params:scim:schemas:extension:figma:enterprise:2.0:User"
"userName": "scimuser@example.com",
"externalId": "123456789",
"displayName": "Scim User",
"urn:ietf:params:scim:schemas:extension:enterprise:2.0:User": {
"costCenter": "323245",
"department": "Mobile Engineering",
"organization": "Product"
"urn:ietf:params:scim:schemas:extension:figma:enterprise:2.0:User": {
"figmaAdmin": false
"id": "974343320676444348",
"meta": {
"resourceType": "User",
"created": "2021-05-12T16:12:30Z",
"lastModified": "2021-05-12T16:12:30Z",
"version": "W/\"1620835950\"",
"location": "https://www.figma.com/scim/v2/964615200748176016/Users/974343320676444348"
POST Users
Provisions a new or existing user in Figma. For existing users, this will bind your identity provider with a username that was created within Figma. The parameters provided are applied to the Figma user whose email matches the userName parameter.
HTTP endpoint
POST :baseURL/Users
Headers
Content-Type = application/json
Parameters
| Body parameter | Description |
| schemas |
| userName |
| active |
| roles |
| externalId |
| displayName |
| title |
| givenName |
| familyName |
| employeeNumber |
| costCenter |
| organization |
| division |
| department |
| managerValue |
| managerDisplayName |
| figmaAdmin |
This request also supports custom parameters.
Example request body
"schemas": [
"name": {
"roles" : [
"type": "seatType",
"value": "Dev"
"emails": {
"primary": "true",
"type": "work"
"figmaAdmin": false
Example response body
"schemas": [
"name": {
"roles": [
"type": "seatType",
"value": "Dev"
"emails": {
"primary": "true",
"type": "work"
"figmaAdmin": false
"id": "977321366678728562",
"meta": {
"created": "2025-02-27T21:39:39Z",
"lastModified": "2025-02-27T21:40:20Z",
"version": "W/\"1740692420\"",
"location": "https://www.figma.com/scim/v2/964615200748176016/Users/977321366678728562"
PUT Users
Overwrites the attributes for a user with the provided parameters in the request body. The parameters provided are applied to the Figma user whose email matches the userName parameter. In order to update attributes, you must know the Figma ID of the user and include the ID at the end of the Users path. Common use cases for this operation are changing emails, updating display names, and adding cost center values.
HTTP endpoint
PUT :baseURL/Users/:figmaUserId
:figmaUserId is a required path parameter, the Figma user ID of the operation's target user.
For example, a user ID returned from GET :baseURL/USERS: "id": "977321366678728562"
Headers
Authorization = "Bearer [FIGMA API TOKEN]"
Parameters
| schemas |
| userName |
| active |
| roles |
| externalId |
| displayName |
| title |
| givenName |
| familyName |
| employeeNumber |
| costCenter |
| organization |
| division |
| department |
| managerValue |
| figmaAdmin |
"schemas": [
"name": {
"roles" : [
"type": "seatType",
"value": "Full"
"emails": {
"primary": "true",
"type": "work"
"figmaAdmin": false
"schemas": [
"name": {
"roles": [
"type": "seatType",
"value": "Full"
"emails": {
"primary": "true",
"type": "work"
"figmaAdmin": false
"meta": {
"lastModified": "2025-02-27T23:38:04Z",
"version": "W/\"1740699484\"",
PATCH Users
Updates a targeted user attribute based on the request body. The parameters provided are applied to the Figma user whose email matches the userName parameter. In order to update attributes, you must know the Figma user ID of the user and populate this at the end of the Users path. Common use cases for this operation are changed emails, updated display names and adding cost center values.
HTTP endpoint
PATCH :baseURL/Users/:figmaUserId
Headers
Parameters
| schemas |
| userName |
| active |
| roles |
| externalId |
| displayName |
| title |
| givenName |
| familyName |
| employeeNumber |
| costCenter |
| organization |
| division |
| department |
| managerValue |
| figmaAdmin |
This example request gives an existing user a Dev seat.
"schemas": ["urn:ietf:params:scim:api:messages:2.0:PatchOp"],
"Operations": [
"op": "replace",
"path": "roles",
"value": [
"type": "seatType",
"value": "Dev"
"name": {
"roles": [
"type": "seatType",
"value": "Dev"
"emails": {
"type": "work",
"primary": "true"
"schemas": [
"figmaAdmin": false
"meta": {
"lastModified": "2025-02-27T23:05:42Z",
"version": "W/\"1740697542\"",
DELETE Users
Permanently deletes the user from Figma and the SCIM Provisioning log associated with Figma. A Figma user ID is required for this operation. You can retrieve a Figma user ID by leveraging the GET users endpoint with an email filter. Returns 204 if the user is successfully deleted.
HTTP endpoint
DELETE :baseURL/Users/:figmaUserId
Headers
Response
204
Note: An easy way to validate deletion is to try to get the user with an email filter or review the get users list.
Groups endpoints
GET Groups
Returns a list of SCIM managed groups in the organization.
HTTP endpoint
GET :baseURL/Groups
Example paths
GET :baseURL/Groups?filter&count&startIndex
GET :baseURL/Groups?filter=displayName eq "ExampleWorkspaceName"
GET :baseURL/Groups?filter=externalId eq "external-id-value"
Headers
Parameters
| filter |
| count |
| startIndex |
"schemas": [
"totalResults": 1,
"Resources": [
"schemas": [
"urn:ietf:params:scim:schemas:core:2.0:Group"
"id":"1b5f9234-df40-4664-9767-334fdd7d51f6",
"members": [
"value":"1427545874257949557",
"display":"scimuser@example.com"
"external_id": "32a50c8f-798b-4040-b2e3-daf6e71ffd88",
"displayName": "bill_group1",
"meta": {
"resourceType":"Group",
"created":"2024-10-17T02:22:22Z",
"lastModified":"2024-10-17T02:22:23Z",
"version":"W/\"1729131743\"",
"location":"https://www.figma.com/scim/v2/TENANTID/Groups/1b5f9234-df40-4664-9767-334fdd7d51f6"
POST Groups
Creates a SCIM group linked to an existing Figma workspace, or billing group, or both. The parameters define the SCIM group's name along with its corresponding members. Members of a SCIM group automatically inherit the workspace or billing group that matches the displayName parameter.
HTTP endpoint
POST :baseURL/Groups
Headers
Parameters
| schemas |
| displayName |
| externalId |
| members |
"schemas": [
"displayName": "bill_group_1",
"members": [
"value": "1427545874257949557",
"display": "scimuser@example.com"
"schemas":[
"id":"185607a2-cae4-46f5-9ab0-1d12dbd1af29",
"members":[
"external_id":"123456789",
"displayName":"bill_group_1",
"meta": {
"created":"2024-10-17T02:56:11Z",
"lastModified":"2024-10-17T02:56:11Z",
"version":"W/\"1729133771\"",
"location":"https://www.figma.com/scim/v2/TENANTID/Groups/185607a2-cae4-46f5-9ab0-1d12dbd1af29"
PUT Groups
Overwrites the attributes of a group with the provided parameters in the request body. The parameters provided are applied to the SCIM group. In order to update attributes, you must know the Figma group ID of the group and populate this at the end of the groups path. Common use cases for this operation are updating membership and updating display names.
When you use this endpoint to add or remove members:
- New members inherit the Figma workspace or billing group that is linked to the SCIM group.
- Removed members no longer inherit the Figma workspace or billing group.
HTTP endpoint
PUT :baseURL/Groups/:figmaGroupId
:figmaGroupId is a required path parameter, the Figma group ID of the operation's target group.
For example, a group ID returned from GET :baseURL/Groups: "id": "1b5f9234-df40-4664-9767-334fdd7d51f6"
Headers
Parameters
| schemas |
| displayName |
| externalId |
| members |
"schemas": [
"displayName": "bill_group_2",
"members": [
"schemas": [
"members": [
"displayName":"bill_group_2",
"meta": {
"lastModified":"2024-10-17T03:51:36Z",
"version":"W/\"1729137096\"",
In this example, the lastModified field matches when the operation is successfully completed.
PATCH Groups
Updates a targeted group attribute based on the request body. The parameters provided are applied to the SCIM group. In order to update attributes, you must know the Figma group ID of the group and populate this at the end of the groups path. Common use cases for this operation are updating membership and updating display names.
HTTP endpoint
PATCH :baseURL/Groups/:figmaGroupId
Headers
Parameters
| schemas |
| displayName |
| externalId |
| members |
"schemas": [
"Operations": [
"op":"replace",
"value":
"displayName": "updatedGroup"
"schemas": [
"id": "1b5f9234-df40-4664-9767-334fdd7d51f6",
"members": [
"external_id": "123456789",
"displayName": "updatedGroup",
"meta": {
"resourceType": "Group",
"created": "2024-10-17T02:22:22Z",
"lastModified": "2024-10-17T04:03:06Z",
"version": "W/\"1729137786\"",
"location": "https://www.figma.com/scim/v2/1401286822445493852/Groups/1b5f9234-df40-4664-9767-334fdd7d51f6"
DELETE Groups
Permanently deletes a group from Figma and the SCIM Provisioning log associated with Figma. Requires a Figma group ID. You can retrieve a Figma group ID using the GET groups endpoint. Returns 204 if the group is successfully deleted.
HTTP endpoint
DELETE :baseURL/Groups/:figmaGroupId
Headers
Response
204
