Working with Variables
Variables in Figma design store reusable values that can be applied to all kinds of design properties and prototyping actions. They help save time and effort when building designs, managing design systems, and creating complex prototyping flows.
Use your plugin to interact with variables in Figma, including creating and reading variables. The Plugin API provides methods using the figma.variables global object to interact with variables.
This guide contains the following sections:
- Get variable collections and variables
- Create variable collections and variables
- Nodes and bound variables
- Typography variables
- Extended variable collections
- Helpers
- Samples
This guide assumes that you’re familiar with the basics of creating Figma plugins. If you’re new to developing plugins, check out the Build your first plugin course — you can copy and paste the code from this guide into the plugin you build.
Use one of the following methods to let your plugin get variables and variable collections.
getLocalVariableCollectionsAsync
The figma.variables.getLocalVariableCollectionsAsync method returns all local variable collections in the current file.
Example usage:
const localCollections = await figma.variables.getLocalVariableCollectionsAsync();
getVariableCollectionByIdAsync
The figma.variables.getVariableCollectionByIdAsync method finds a variable collection by ID. If not found or the provided ID is invalid, returns null.
Example usage:
const collection = await figma.variables.getVariableCollectionByIdAsync('VariableCollectionId:257c3beb2/57:13');
getLocalVariablesAsync
The figma.variables.getLocalVariablesAsync method returns all local variables in the current file, optionally filtering by resolved type.
Example usage:
const localVariables = await figma.variables.getLocalVariablesAsync('STRING'); // filters local variables by the 'STRING' type
getVariableByIdAsync
The figma.variables.getVariableByIdAsync method finds a variable by ID. If not found or the provided ID is invalid, returns null.
Example usage:
const variable = await figma.variables.getVariableByIdAsync(variableId);
Use one of the following methods to create variables or variable collections.
createVariableCollection
To create a variable collection, use the figma.variables.createVariableCollection method.
Example usage:
const collection = figma.variables.createVariableCollection('Example Collection');
createVariable
To create a variable, use the figma.variables.createVariable method.
Example usage:
const variable = figma.variables.createVariable(
'ExampleVariableName',
collection,
'STRING'
This example creates a variable with the name ExampleVariableName of the STRING type. The variable is created inside a collection with the ID 57:13.
For a variable to apply its value to a node, the variable must be bound to the node. In the context of the Figma user interface, when a variable is applied to a node (for example, if you set a color variable for a stroke on a rectangle), the alias for that variable is captured in the boundVariables property of the node.
You can also use the Plugin API to bind variables to nodes with our helper methods, and the setBoundVariable method that is available for many types of nodes. For a list of the supported nodes, see setBoundVariable.
To use setBoundVariable, you must provide a valid bindable field and the variable that you want to bind to the field. The variable that you're binding must match the data type of the field. For example, the SHAPE_WITH_TEXT node has an opacity property that accepts numbers. In this case, the variable you bind to opacity must be a number variable.
The following example creates a variable collection and variable, and then applies that variable to an example node.
const collection = figma.variables.createVariableCollection("example-collection")
const widthVariable = figma.variables.createVariable("width-variable", collection, "FLOAT")
const exampleNode = await figma.getNodeByIdAsync("1:4")
// Simple fields can be bound using setBoundVariable
exampleNode.setBoundVariable("width", widthVariable)
To get the aliases for variables that are bound to a node, use the boundVariables property on nodes.
const exampleNodeVariables = exampleNode.boundVariables
/* Example boundVariables object:
"strokes": [
"type": "VARIABLE_ALIAS",
"id": "VariableID:1:7"
To unbind or remove a variable from a node, set the bound field to null.
// Simple fields can be unbound using setBoundVariable and null
exampleNode.setBoundVariable("width", null)
To learn more about binding variables, check out the code samples.
Typography variables are used to control complex type across your Figma files and design systems. You can use typography variables to manage everything from typeface to the spacing between characters and paragraphs.
Variables can be used to control text styling for TextNodes, TextSublayers (substrings of styled text), and TextStyles. Paragraph spacing and indentation cannot be applied to TextSublayers.
The following properties are bindable:
fontFamily: Accepts string variables. The value for the variable must correspond to a font name, such asInter.fontStyle: Accepts string variables. The value for the variable must map to a valid style for the font. The specific style values depend on the font you are using. For example, whenfontFamilyisInter,fontStylecan be set to values such asLight,Regular, orSemi Bold, among other styles supported by the font.fontWeight: Accepts number variables. If the number value doesn't correspond to a valid weight for the font, the closest valid weight is used.lineHeight: Accepts number variables.letterSpacing: Accepts number variables.paragraphSpacing: Accepts number variables. Not valid for substrings.paragraphIndent: Accepts number variables. Not valid for substrings.
Apply typography variables
To apply typography variables to a TextNode, use the setBoundVariable method as you would with other variables.
const weightVariable = figma.variables.createVariable("weight-variable", collection, "FLOAT")
const exampleTextNode = await figma.getNodeByIdAsync("1:4")
// Typography variables can be bound using setBoundVariable
exampleTextNode.setBoundVariable("fontWeight", weightVariable)
To apply typography variables to a substring, use the setRangeBoundVariable method that is available for TextNodes.
// Typography variables can be bound to ranges of text with setRangeBoundVariable
exampleTextNode.setRangeBoundVariable(0, 5, "fontWeight", weightVariable)
To apply typography variables to a TextStyle, use the setBoundVariable method, similar to how you bind typography variables to TextNodes.
// Uses the first available local style as an example
const localTextStyles = await figma.getLocalTextStylesAsync()
const exampleTextStyle = localTextStyles[0]
exampleTextStyle.setBoundVariable("fontWeight", weightVariable)
Get typography variables
To get the aliases for typography variables that are bound to a TextNode, use the boundVariables property of the TextNode.
const exampleTextNodeVariables = exampleTextNode.boundVariables
To get the typography variables for segments of text, use the TextNode.getStyledTextSegments method with boundVariables.
exampleTextNode.getStyledTextSegments(['boundVariables'])
/* Example output
characters: "hello",
start: 0,
end: 5,
boundVariables: {
fontFamily: { type: "VARIABLE_ALIAS", id: "VariableID:1:7" }
characters: " world",
start: 5,
end: 11,
boundVariables: {
fontFamily: { type: "VARIABLE_ALIAS", id: "VariableID:2:8" }
You can also use the TextNode.getRangeBoundVariable method to get a specific bound variable based on the character range and field (fontWeight, for example).
// Get typography variables that are bound to ranges of text with getRangeBoundVariable
exampleTextNode.getRangeBoundVariable(0, 5, "fontWeight")
To get typography variables that are bound to TextStyles, use the boundVariables property of the TextStyle, similar to TextNodes.
const exampleTextStyleVariables = exampleTextStyle.boundVariables
Remove typography variables
To unbind or remove a typography variable, set the bound field to null.
exampleTextNode.setBoundVariable("fontWeight", null)
To learn more about binding typography variables, check out the code samples.
This feature is limited to the Enterprise plan.
Extended variables collections enable theming for variables. Extended collections inherit the modes and variables from their parent collection. In an extended collection, a variable mode value can be overridden from its default value to give it a theme-specific value.
To create an extended variable collection, use the extend method on a local variable collection or use the extendLibraryCollectionByKeyAsync method for extending library variable collections.
// extend a local variable collection
const localCollection = figma.variables.createVariableCollection("example-collection")
const extendedCollection = localCollection.extend("extended-collection-1")
// extend a library variable collection
const libraryCollection = await figma.variables.getVariableCollectionByIdAsync("VariableCollectionId:1:3")
const extendedCollection = await figma.variables.extendLibraryCollectionByKeyAsync(libraryCollection.key, "extended-collection-2")
Modes on an extended collection have unique IDs that are encoded with the collection's ID. These modes map to their parent mode via the parentModeId property.
The default values for variables in an extended collection can be overridden with theme-specific values. Use the setValueForMode method with the modeId from the extended collection to override a variable value in an extended collection.
Note: The variable itself only exists in the parent collection and is not duplicated in the extended collection.
const modeId = extendedCollection.modes[0].modeId // example: "VariableCollectionId:1:3/0:1"
const variable = await figma.variables.getVariableByIdAsync(extendedCollection.variableIds[0])
variable.setValueForMode(modeId, {r: 1, g: 0, b: 0})
Since variables are not duplicated in extended collections, variable.valuesByMode will still only return the values from the parent collection (the default values). To see the inherited and overridden variable values in an extended collection use the variable.valuesByModeForCollectionAsync method. To see all overridden values for all variables inherited by an extended collection use the variableOverrides property on the extended collection.
const values = await variable.valuesByModeForCollectionAsync(extendedCollection)
console.log(values)
// Example output:
// {"VariableCollectionId:1:3/0:1": { r: 1, g: 0, b: 0, a: 1 } }
const overrides = extendedCollection.variableOverrides
console.log(overrides)
// Example output:
// { "VariableID:1:4": { "VariableCollectionId:1:3/0:1": { r: 1, g: 0, b: 0, a: 1 } } }
To remove an overridden variable value and revert the mode value to its inherited value, use the removeOverrideForMode method on the extended collection. To remove all overridden values for a variable, use the removeOverridesForVariable method on the extended collection.
variable.removeOverrideForMode(extendedCollection.modes[0].modeId)
extendedCollection.removeOverridesForVariable(variable.id)
Helpers
The figma.variables global object also provides some helper methods to make certain operations easier.
createVariableAlias
The figma.variables.createVariableAlias method is a helper function to create a variable alias. Variable aliases are used to bind variables to other variables, or to bind variables to various properties on a node or style.
createVariableAliasByIdAsync(variableId)
The figma.variables.createVariableAliasByIdAsync(variableId) method is a helper function that accepts a variable ID and returns an alias that references that variable.
setBoundVariableForPaint
The figma.variables.setBoundVariableForPaint method is a helper function to bind a variable to a SolidPaint.
setBoundVariableForEffect
The figma.variables.setBoundVariableForEffect method is a helper function to bind a variable to an Effect.
setBoundVariableForLayoutGrid
The figma.variables.setBoundVariableForLayoutGrid method is a helper function to bind a variable to a LayoutGrid.
importVariableByKeyAsync
The figma.variables.importVariableByKeyAsync method loads a variable from the team library.
Samples
This section contains some functional plugin samples that use variables.
Example: Authoring a new variable collection
This example creates a new variable collection with two modes, and a color variable that defines a value for each of those two modes.
const collection = figma.variables.createVariableCollection("new-collection")
collection.renameMode(collection.modes[0].modeId, "light")
const colorVariable = figma.variables.createVariable("color-variable", collection, "COLOR")
// rename our new variable and collection because naming is hard!
colorVariable.name = "text-primary"
collection.name = "semantic colors"
const lightModeId = collection.modes[0].modeId
const darkModeId = collection.addMode("dark")
// Sets the color to #000 in light mode and #fff in dark mode
colorVariable.setValueForMode(lightModeId, {r: 0, g: 0, b: 0})
colorVariable.setValueForMode(darkModeId, {r: 1, g: 1, b: 1})
Example: Determining if a node is bound to a variable
Variables consumed by a given node are enumerated in the boundVariables map.
const rectangle = await figma.getNodeByIdAsync(rectangleId)
// rectangle.width is a number
if (rectangle.boundVariables['width'] !== undefined) {
// Width fields can only have one bound variable, but fills and strokes might have multiple.
const widthVariableId = rectangle.boundVariables['width'].id
const widthVariable = await figma.variables.getVariableByIdAsync(widthVariableId)
// At this point we know that `widthVariable` is bound to the `width` property of `rectangle`.
assert(widthVariable.resolveForConsumer(rectangle).value === rectangle.width)
Example: Binding a variable to a node or style
Whether binding to a node or style, the procedure is roughly the same.
const node = await figma.getNodeByIdAsync(...)
// Simple fields can be bound via setBoundVariable
node.setBoundVariable('width', widthVariable)
const fillsCopy = clone(node.fills)
// Fills and strokes must be set via their immutable arrays
fillsCopy[0] = figma.variables.setBoundVariableForPaint(fillsCopy[0], 'color', colorVariable)
node.fills = fillsCopy
const style = await figma.getStyleByIdAsync(...)
const paintsCopy = clone(style.paints)
paintsCopy[0] = figma.variables.setBoundVariableForPaint(paintsCopy[0], 'color', colorVariable)
style.paints = paintsCopy
// Effects and LayoutGrids must also be set by their immutable arrays
const radiusVariable = figma.variables.createVariable("radius-variable", collection, "FLOAT")
const effectsCopy = clone(node.effects)
effectsCopy[0] = figma.variables.setBoundVariableForEffect(effectsCopy[0], 'radius', radiusVariable)
node.effects = effectsCopy
const countVar = figma.variables.createVariable("count-variable", collection, "FLOAT")
const layoutGridsCopy = clone(node.layoutGrids)
layoutGridsCopy[0] = figma.variables.setBoundVariableForLayoutGrid(layoutGridsCopy[0], 'count', countVar)
node.layoutGrids = layoutGridsCopy
Example: Binding a variable to a variant property
This sample binds a string variable to the variant property on a InstanceNode
const instanceNode = await figma.getNodeByIdAsync(...);
const stringVariable = await figma.variables.getVariableByIdAsync(...);
node.setProperties({
"variantPropName":
figma.variables.createVariableAlias(stringVariable)
// To clear
"variantPropName": "Default", // or other string value
Example: Binding a variable to a text node
This sample binds a font family variable to text node.
(async () => {
// Setup variables
const modeId = collection.modes[0].modeId
const fontFamilyVar = figma.variables.createVariable("fontFamily", collection, "STRING")
fontFamilyVar.setValueForMode(modeId, "Roboto")
// Load necessary fonts
await figma.loadFontAsync({ family: "Inter", style: "Regular" }) // current font
await figma.loadFontAsync({ family: "Roboto", style: "Regular" }) // new font
// Create text node
const text = figma.createText()
text.characters = "Hello world!"
// Apply variables
text.setBoundVariable("fontFamily", fontFamilyVar)
Example: Binding a variable to a text style
This sample binds a font family variable to a text style.
(async () => {
// Setup variables
// Create style
const textStyle = figma.createTextStyle()
// Create text node
text.setTextStyleIdAsync(textStyle.id)
// Apply variables
textStyle.setBoundVariable("fontFamily", fontFamilyVar)
console.log(textStyle.boundVariables)
// Output:
// fontFamily: [{
// type: "VARIABLE_ALIAS",
// variableId: fontFamilyVar.id
Example: Binding a variable to a text substring
This example binds font family and font style variables to a substring of text.
(async () => {
// Setup variables
const fontStyleVar = figma.variables.createVariable("fontFamily", collection, "STRING")
fontStyleVar.setValueForMode(modeId, "Bold")
await figma.loadFontAsync({ family: "Inter", style: "Bold" }) // new font
// Create text node
// Apply variables
text.setRangeBoundVariable(0, 5, "fontStyle", fontStyleVar)
console.log(text.getRangeBoundVariable(0, 5, "fontStyle"))
// Output:
// variableId: fontStyleVar.id
console.log(text.getRangeBoundVariable(0, 6, "fontStyle"))
// Output:
// Symbol(figma.mixed)
console.log(text.getStyledTextSegments(["boundVariables", "fontName"]))
// Output:
// characters: "Hello",
// start: 0,
// end: 5,
// fontName: { family: "Inter", style: "Bold" },
// boundVariables: {
// fontStyle: { type: "Variable_ALIAS", variableId: fontStyleVar.id }
// characters: " world!",
// start: 5,
// end: 12,
// fontName: { family: "Inter", style: "Regular" },
// boundVariables: {}
Example: Extracting variables from fill styles
Sample code to convert existing styles into variables is available on our GitHub.
Example: Import and export variables
Sample code to help import design tokens from other products or export variables into JSON format. This can further help with migration to variables or syncing design with development. Note that this sample only handles basic import/export and developers are encouraged to extend and customize this code to suit their specific needs.
