Asynchronous Tasks
This article covers asynchronous tasks in JavaScript and provides code examples. It may be helpful to understand some JavaScript fundamentals before you continue. Check out the required knowledge here →
The Plugin API and Widget API include both synchronous and asynchronous functions. Usually, asynchronous functions in the Plugin API and Widget API are identified by an Async
suffix, such as loadFontAsync()
In this article, we’ll explain the differences between the two. We'll also explore how asynchronous functions can make your API communication more effective and why Figma favors asynchronous code for some plugin operations.
Synchronous requests
With synchronous requests, the caller must wait for a response before other requests are made. Synchronous requests are used when data is expected to return immediately. In the case of a Figma plugin, the client is usually the active tab of a web browser or the Figma desktop app.
You have likely encountered these kinds of tasks in other situations, like waiting for a photo to upload before you can continue using an application. During this time you could see a progress bar, spinning circle, or loading screen.
You can think of synchronous requests like getting in line at the grocery store or drive through. Each request is handled one at a time. Unlike at the grocery store, synchronous tasks can’t jump the queue. Those who were in line before you must complete their transactions before you can move forward and begin your own check out process.
Typically, code written in JavaScript runs one line at a time, in the order it was written. Consider the following code:
console.log("I am");
console.log("synchronous");
console.log("JavaScript");
As JavaScript is synchronous by default, the console output looks like:
- “I am” is the first output in the JavaScript console.
- “synchronous” is the next output.
- “JavaScript” is the final output.
While synchronous programming works in this example, synchronous tasks aren’t always the best approach. Since each task must wait for the previous request to receive a response before proceeding, it can slow down larger, more complex applications where response times are unpredictable.
This is especially true when network requests and latency are added as considerations. Since you can’t guarantee how fast or stable a user’s internet connection is (that is, how long it will take to transfer data to and from the user) or how long it might take a server to respond to a request, the potential slowdown to synchronous code can be significant.
Asynchronous requests
Unlike synchronous requests, asynchronous requests don’t need to wait on a response before proceeding. Instead, a callback is provided to notify the client when a response is ready. Asynchronous requests are useful when an API’s response time varies based on the availability of a resource.
You can think of this as ordering something from a coffee shop. You get in line, your order is taken, then you give your name so the barista can call you when your order is ready. In an API, your name is the request token or unique identifier.
In a coffee shop, orders won’t always come out in the order they were placed. An americano will take less time than a frothy coffee with latte art! The same can be said of asynchronous requests.
This way, other requests can continue to process in the background and the application can keep its functionality while waiting for responses. An asynchronous approach can be an efficient solution when the API’s response time is unpredictable due to variables in data size and complexity.
Learn more about asynchronous JavaScript in the MDN Web Docs →
Promises
As the client doesn’t need to wait for a response from the API, we need another way to communicate the status of that task. This is where Promises come into play.
Asynchronous programming in modern JavaScript is built on the concept of Promises. A Promise is an object returned by an asynchronous request and can be in one of three states:
- Pending: The promise has been created but the request has not been fulfilled or rejected.
- Fulfilled: The asynchronous request was successful. When a promise is fulfilled, the
.then()
handler is called. - Rejected: The asynchronous request failed. When a promise is rejected, the
.catch()
handler is called.
