cloneWidget
Create a copy of this WidgetNode while overriding specific synced state & synced map values for the widget.
Overrides are only applied if a widget is cloning itself or other widgets created by the same manifest.id.
Supported on:
Signature
cloneWidget(syncedStateOverrides: { [name: string]: any }, syncedMapOverrides?: { [mapName: string]: { [key: string]: any } }): WidgetNode
Parameters
synced state values to override in the new WidgetNode.
Each key/value pair in this object will override the corresponding useSyncedState(<key>) value.
Similar to WidgetNode.clone, the duplicate will be parented under
figma.currentPage. If you are relying on the x, y or the relativeTransform of the original widget, make sure
to account for the case where the original widget is parented under a different node (eg. a section).
syncedMapOverrides
synced maps to override in the new WidgetNode.
Each key in this object will override the entire corresponding useSyncedMap(<key>) value if specified.
NOTE: every key in syncedMapOverrides will override the entire corresponding synced map, deleting all existing keys in the map. If you wish to preserve some of the keys in the map, you'll need to explicitly specify them in the override.
For more information, check out this page in our widget documentation.
