on
Registers a callback that will be invoked when an event occurs on the page. Current supported events are:
"nodechange": Emitted when a node is added, removed, or updated.
Supported on:
Signature
on(type: 'nodechange', callback: (event: NodeChangeEvent) => void): void
Parameters
type
The type of event to listen for.
callback
The callback to be invoked when the event occurs.
Remarks
Available event types
"nodechange"
This event will be emitted when a node on the page is added, removed, or updated.
The callback will receive a NodeChangeEvent with the below interface:
interface NodeChangeEvent {
nodeChanges: NodeChange[]
There are 3 different NodeChange types. Each of these changes has a type property to distinguish them:
| Change | type property | Description |
CreateChange | 'CREATE' | A node has been created in the page. If a node with nested children is being added to the page a CreateChange will only be made for the highest level parent that was added to the page. |
DeleteChange | 'DELETE' | A node has been removed from the page. If a node with nested children is being removed from the page a DeleteChange will only be made for the highest level parent that was removed from the page. |
PropertyChange | 'PROPERTY_CHANGE' | A property of a node has changed. |
